Hello, as you have all seen on the server, a new rank system as been established. This post is to answer any questions you may have and also to clear up any misunderstandings.
First let's talk about why this was implemented.
Our server as it is, is simply too big to have a manual ranking system such as ours. There is no way that a small group of people can keep up with hundreds of unique players in order to fairly deal with promotions. The majority of players were [Player] rank. Many of these players have been on the server for months and even years and were unnoticed due to how big we were. The same goes for certain [AdvPlayer] and Vips. That was a big issue. Many players felt like they were stuck on a rank for what seemed eternities. With this, the server has also been dwindling in popularity. Our numbers were dropping steadily and if nothing was done, this trend would continue. With this system, I was able to combine an auto rank system with something that can put us back on the boards in terms of popularity. Of course no system is perfect. Some players feel like the new ranking system is a demotion, or devalues the rank. If you have any questions or concerns please post below.
Now to the ranks themselves.
We have added many new ranks. There are now 10 ranks under the first staff rank which is Enforcer. Keep in mind, there will be perks added to these ranks. If you are already Experienced, subtract 110 from the required votes of the next rank. For example experienced to advanced requires only 90 more votes if you are experienced.
Please suggest some perk ideas here in this thread ---> https://hometownmc.com/forums/showthread.php?tid=48
Default Guest
3 votes Rookie
12 votes Regular
50 votes Member
110 votes Experienced
200 votes Advanced
330 votes Adept
After this, the expert rank will be given out similar to how trusted was given out. This is to keep some form of prestige to ranks for the members who feel like ranks should require more than just playtime. This rank can be achieved after advanced or adept (usually the latter).
Expert
180 votes Veteran
Elite
The elite rank will be chosen from the pool of veteran players. Elite will have the ability to use /kick and possibly a temporary mute. These players should help out in case there are no staff online by dealing with trouble makers. This rank will be the last player rank before Enforcer.
For VIP ranks, I am still trying to figure out a good system for them. Should VIPs have their own set of vote perks/ranks? Should VIPs be implemented into the current system? example: IPs automatically get [Advanced] rank.
I am also wanting to change the VIP rank names
If you have any ideas regarding VIP rank names and how should VIPs fit in to this system please post your suggestions in this thread ---> https://hometownmc.com/forums/showthread.php?tid=48
Default Guest
3 votes Rookie
12 votes Regular
50 votes Member
200 votes Advanced
330 votes Adept
Expert
180 votes Veteran
Elite
![[Image: UvdzAjN.png]](https://i.imgur.com/UvdzAjN.png)
![[Image: tWuSvOo.gif]](http://i.imgur.com/tWuSvOo.gif)
