  • 1 Vote(s) - 5 Average
Comprehensive Redstone Tutorial
Ladies and Gentlemen,
As promised a month ago, I have completed my Comprehensive Redstone Tutorial.
The tutorial consists of a text file in PDF that matches the in-game tutorials.
The tutorial is at Warp RST.
Please do NOT grief, do NOT change states of any repeaters or comparators.
Also, Do NOT build any solutions Near the tutorial grounds, or the solution place.
You, however, can walk anywhere in the tutorial ground to look at redstone closely, or interact with any levers, buttons, minecarts, chests or pressure plates to aid your understanding.
For the Tutorial, Iron Blocks are solid blocks, Gold Blocks are powered blocks or circuit outputs. 1-wide divider divides bullet points, 2-wide dividers divides subsections.
Please let me know of any broken mechanisms or inaccurate information.
Have Fun!!! Text file is attached below!
[Image: n0YC0WJ.png]
.pdf   MCRStut.pdf (Size: 154.21 KB / Downloads: 26)
Sound good
Sent from my SM-J320FN using Tapatalk
Ill check it out if i remember
Thanks for the tutorial. I finally understood how to make a CUD and a vertical double piston extender.
You have reached redstone support. How may we help?
Spot any mistakes? Seems like you know redstone already.
(10-12-2016, 11:32 PM)_JELLy__ Wrote: Spot any mistakes? Seems like you know redstone already.
No mistakes in the tutorial grounds. You said you only need 4 pistons instead of 6 to make a jeb door in the exercise part of the pdf.(That's the only one I found.)
Thread moved.
[Image: sVvtyQE.jpg]
Jelly! This is amazing, as most things you build. Miss you buddy!
Browsing: 15 Guest(s)
