Time spent
I've honestly gotta ask, is it possible to see how long you have been on the server's? Is there a command or something? I can't check the logs because I started hometown on a laptop I no longer own.
-Two broken arms and a loving mom
iKea
Proud Owner Of KeaHomes RealEstate @ warp KeaHomes
[Image: jeicCB]
(03-02-2017, 12:21 AM)Alex_Utley Wrote: I've honestly gotta ask, is it possible to see how long you have been on the server's? Is there a command or something? I can't check the logs because I started hometown on a laptop I no longer own.
You could always try using the standard Minecraft stats on the pause menu?
[Image: bcNtqPw.png]
Sometimes it's best not to know. Another server I've played on displays how much time you've spent there whenever you log in. When you see something like this (below) you end up asking yourself questions about what you're doing with your life.  XD
[Image: wastedtime.jpg]
- Gaming Since The 80's
Use memory. If you dont have one, i suggest you go meet the doctor.
-0,0 days without a sh*tpost
-Forum dwelling since 2015!
minecraft appdata files, Should tell you your first sign on to the servers port then i think another file shows exactly how much time minecraft has been running.
Mechanic, Landrover lover, dont let me near a welder and an oxy torch Big Grin
[Image: CZo9VnF.png]
