3 Block Challenge
So I caught a video a while back of players doing a "3 block challenge" and thought it might be cool to do and see if others want to try. The basics are simple: build a structure using only 3 block types. The hitch: use three types that don't normally go together or blocks you don't generally use.
So here's my challenge to y'all: The 3 block choices are
Red Sandstone (including half slabs and stairs)
Dark Prismarine
Snow block.
The goal: build a structure that will fit in one chunk (16x16 blocks) using only these blocks.
Exceptions: you may light the structure as long as the lighting is not part of the structure (i.e. placing lamp posts outside the build, sinking glowstone into the ground around the build, placing torches inside to light it up).
Take a screenshot and post it to this thread if you do this challenge. I am interested to see what people come up with.
Just enough of a Bastard to be worth liking.
Browsing: 2 Guest(s)
