Poll: How useful or interesting did you find this post?
Very
Moderately
Not at All
[Show Results]
Note: This is a public poll, other users will be able to see what you voted for.
Minecraft 1.13 Guides, Tutorials, and Information
Good Morning, Afternoon, Evening or whatever arbitrary time it is for you now!
My name is Peashooter101, also known as Peashooter102 or 4a_61_72_65_64.
With the upcoming 1.13 update coming to HomeTown on September 21st, I thought I would collect a list of a few links about Aquatic Update relevant material that some of you may find useful, useless, or be indifferent about.
I had also just found out that YouTube Embedded Videos don't show up in the result...  Sad
If you have anything that you'd like to add to this list, let me know, you will be credited underneath the video / link, this thread will update from time to time if more content relating to 1.13 is found.
Thread Last Updated: 2018 / 09 / 17
So why don't we get started?
Contents
Please Note: I cannot make spoiler blocks so each "section" is divided by a horizontal line and a Header.
Item, Mob, and Experience Farming: This section talks about item, mob, and experience farms or applications directly related to these farms.
Utility and Redstone: This section talks about useful little builds or Redstone builds.
Building and Design: This section talks about building uses and designs for 1.13 related items and blocks.
Information and Knowledge: This section talks about the general 1.13 changes, how it works, etc.
docm77's 1.13 AFK Fishing Farm *NEW*https://youtu.be/GYIP9150raY
Video Link provided by thatguy3339
This video is a variation of the 1.13 AFK fishing farm that has been noted to be more reliable on servers than xisumavoid's. Xisumavoid's design is below, however, this may be more reliable on the server in times of lag or server stresses. docm actually notes that Xisuma's works well in single player, but this design is more reliable on multiplayer.
xisumavoid's 1.13 AFK Fishing Farm: https://youtu.be/TJ6CCFoGbig
This video talks about how to build an automatic AFK fishing farm in Minecraft 1.13 due to changes that make the 1.12 version inoperable.
xisumavoid's 1.13 Stored Furnace XP: https://youtu.be/uskkb72uIkk
This video talks about how Furnaces can now store Experience Orbs and can be withdrawn once an item is pulled out of the output slot. This showcase demonstrates a system where you can have just enough experience to fully repair a certain item.
xisumavoid's 1.13 Fish Mob Farm: https://youtu.be/2-imCL-moMs
This video talks about how to create a fish farm (mob based) that spawns fish that actively retrieve fish drops. This system may be useful if you tie it into the Furnace XP Farm concept above to always provide a smelt-able item while you are not Auto-Fishing. Otherwise, Auto-Fishing and Guardian Farms usually get you as much fish as you will ever need.
xisumavoid's Kelp Farm: https://youtu.be/kpo47mCRWuI
This video talks about how to create a Kelp Farm in Minecraft. Kelp is useful as both a building block and a fuel source as Dried Kelp Blocks. As a fuel source, it smelts 20 items total in comparison to coal / charcoal's 8 items per unit. If tied to the Stored Furnace XP video above, this may be more useful.
SwordTV's 1.13 AFK Pool: https://youtu.be/UWiEF-gMOGc
Video Link provided by AmbularD
This video demonstrates how to build an AFK Pool in 1.13. They require a modification as noted by AmbularD in the HomeTown Update Post (link) for proper functioning.
xisumavoid's Trident and Riptide Elevator: https://youtu.be/3QSIBt-L4p4
This video demonstrates how to build an elevator using the Trident and Riptide Enchantment. This elevator allows for vertical travel of 20 blocks per second.
MumboJumbo's Piston Soul Sand / Magma Block Elevator: https://youtu.be/1QRL3Vf8Vb4
This video demonstrates how to create a Soul Sand / Magma Block piston-operated elevator. This utilizes a block switcher in order to change the direction of water pull (down or up, depending on soul sand or magma blocks).
MumboJumbo's Redstone Water Lines: https://youtu.be/4sJD358FvaA
This video demonstrates how to create redstone circuits and some useful applications using water and how water updates affect Observers. This utilizes soul sand to send a block update through the water, which can be detected by Observers. This is useful for creating redstone circuits that can be used underwater.
ilmango's Redstone Leaves Lines: https://youtu.be/xp1u2RlpoxQ
This video demonstrates how to create redstone circuits using leaves and how they work. This method utilizes a new NBT found in leaves known as "distance" and it can be seen in the F3 Block NBT Menu. This change in the distance NBT can be detected by Observers. This is useful for creating redstone circuits that use the build to function (less exposed redstone) or running redstone circuits that can be used underwater.
Building and Design
Grian's Update Aquatic Building Tips and Tricks: https://youtu.be/kUze9GIRCHE
This video talks about little tidbits and tricks that allow you to utilize some of the new 1.13 mechanics.
Grian's Aquarium Designs: https://youtu.be/tvgl_iAljbo
This video talks about design ideas for creating aquariums with the 1.13 fish and mechanics.
xisumavoid's "25 Changes in Minecraft 1.13": https://youtu.be/1whsTryW5Ts
This video covers 25 changes in Minecraft 1.13 as a part of xisumavoid's "Do you know Minecraft?" series.
xisumavoid's "Changes in 1.13": https://youtu.be/hhN5gi3TgSo
This video talks about changes from 1.13 to 1.13.1 covered by xisumavoid.
xisumavoid's Ocean Exploration Tips and Tricks: https://youtu.be/4dgoqfSBq1U
This video covers tips and tricks on exploring oceans in 1.13 covered by xisumavoid.
Hope you find this thread useful in any way possible. Like I said earlier, I will add any other videos or links regarding 1.13 that are provided in replies.
Thanks for Reading!
   Jared S.
   Peashooter101 / 4a_61_72_65_64
   DragonPeas Leader
I am the coolest lame guy you will ever meet and witness in your lifetime.
[Image: FYXTFLZ.png]
Are all of these people from hermitcraft or something XD
8/15/2015
7/29/2019
5/3/2022
2/14/2023
(09-17-2018, 08:42 PM)Anonymouse Wrote: Are all of these people from hermitcraft or something XD
For the most part, yes. I mean these people are where I get most of my ideas and information from and they are a huge group so tbh.
I'd actually recommend using Docm's AFK fish farm over Xisuma's
https://www.youtube.com/watch?v=GYIP9150raY&t=54s
Much more simple to build and works like a dream.
(09-17-2018, 11:12 PM)thatguy3339 Wrote: I'd actually recommend using Docm's AFK fish farm over Xisuma's
Appreciate you! Adding it to the list.
Browsing: 10 Guest(s)
